Ok so I got back and tried moving the clutch lever with a wrench, and it worked, i was able to move the clutch arm more and it had a lot of tension on it. Although i'm still facing the problem that i cant brake, once i start the engine, the drive shaft is constantly moving, and theirs no way to stop it with out the engine dying, or it being in neutral. i have a video already posted showing the drive shaft moving the entire time, if you need a better video or more info just ask. As of now, i cant drive it or else i would be constantly moving and there would be no way to brake without the engine dying. pls help thanks
