kill switch
Hello.... ok... on your CDI there is a ground ( kill ) wire.... look at pic .. this kill wire makes a ground contact to the cdi.... check you ignition switch,.... 2 wires are for starting your motor... and 2 wires are for shutting it off... so I think you have electric start .. right??? check and you will see..... 1 wire has battery power.. and 1 wire is ground... when you turn the key on... it lets the power go to the other iwre and powers up th e unit.... the other wire is a ground.... with the key off it lets the ground go thru to the CDI KILL WIRE.... this grounds the spark shutting off the motor... you only need a test light... to check.. I foret if you did say you had electric start ... but it seems like it..
ABIBABA ATV ETC
