Thanks all and I will get a video made. Still having some minor carb issues. Pipes turning blue and needing a lot of choke tells me I'm running lean. Added an inline filter to keep the carb from clogging up again. Plan to replace the cheap gas lines. No idle set screw? The only adjustment I've found is idle/air mix. I've got some more chassis bolts to loctite. The kickstand bolts fell off yesterday. Luckily in the garage floor. Those darn two piece rims were an adventure to loctite. Be glad when the one piece rims arrive so I can toss the inner tubes.
