Right now I have the rear light and headlight Low/High Beam and OFF switch working.
I cant remember if my rear brake light works when I turn the bike on or only when I have the Light Switch in either low or high beam. So I may have to figure out something there.
So with this new Switch I have, is there a OFF switch to shut off the front lights.
What I was going to do is, just use the wires that I got my old switch working and replace it with this new switch, but I'm not to sure on how to control the back left blinker and the front left blinker together, how are the wires hooked up together?
Originally Posted by SpudRider
I suspect the green wire is a ground wire. I suspect the yellow and black wires are employed by the high beam trigger on the front of the switch.
