Originally Posted by rtking
I think the issue is the caliper. In order to get effective braking on the pad, the piston needs to push against the backing plate of the brake pad fairly squarely. The stock caliper will only extend so far due to the size of that piston and the depth of the caliper body.
yeah, it just seems like a mismatch of rotor to caliper - either a deeper caliper or a rotor with less depth available would be a better match.
if they are sourcing existing parts that work to keep costs low then I fully understand. I've done the same thing customizing cars for years, but if they are having them made for the bike then it seems that a simple change to the disk profile that goes to the cutters would make it a little nicer.
