Originally Posted by Moparracer95
... does anyone know if the 150cc and 2xx cc wiring is the same... including the stator...
What's the stock? 2 (yellow/pink) or 3 wire (3 yellow) to rec/reg & diameter
(Most common) 150 uses
http://mall.mxjidian.com/?de=goodsdetail,gid--100030 (88.6 mm/ 2 wire to reg/rec)
Some 250 are fitted w/
http://mall.mxjidian.com/?de=goodsdetail,gid--100023 (93mm/ 3 wire to reg/rec | NEEDS dc-cdi ) or "11" pole [93mm/ 3 wire (9 poles) to reg/rec + 2 poles (The AC source of CDI) ]
Info about this "CG" family
125:
http://item.taobao.com/item.htm?id=38182078672
150:
http://item.taobao.com/item.htm?id=38181870208
175:
http://item.taobao.com/item.htm?id=35713465859
200:
http://item.taobao.com/item.htm?id=36115235290
250:
http://item.taobao.com/item.htm?id=524002726547
