Testing the temperature sensor.
Configure the multimeter to measure ohms (scale 2K). Connect one probe of the multimeter to the electrical terminal of the sensor. Connect the other probe to the sensor body. At a temperature of 20 degrees Celsius, the resistance should be 555 ohms.
Place the temperature sensor in a container of water. Raise the temperature of the water to 82 degrees Celsius. You should obtain a resistance of .056 ohms at 82 degrees Celsius.
"Never argue with an idiot. He will drag you down to his level, and beat you with experience."
Mark Twain
Mods made to my Zongshen ZS200GY-2:
http://www.chinariders.net/showthread.php?t=6894
