Testing the Fuel Gauge Sensor
Disconnect the plug for the fuel tank float. Set the digital multimeter for the 200 ohm range. Connect the multimeter to the sensor terminals. Connect one of the multimeter probes to the yellow/white wire. Connect the other probe to the green wire. The resistance reading for a full tank of fuel is 8 ohms. The resistance reading for an empty tank is 98 ohms.
"Never argue with an idiot. He will drag you down to his level, and beat you with experience."
Mark Twain
Mods made to my Zongshen ZS200GY-2:
http://www.chinariders.net/showthread.php?t=6894
