Originally Posted by roots
Since we are sortof on the topic. I watched the CSC live feed this morning and noticed the chain slack that Gerry allowed looked much more than what I did "following" specs. Basically, I think I set my chain to tight. I can get the appropriate movement up and down but with effort. Gerry's chain looked more like the chain freely moved up and down within spec. Does that make sense? So, do others push and pull (with all your might) the chain to check or gently move the chain up and down?
You should not have to "push and pull (with all your might)."
"Never argue with an idiot. He will drag you down to his level, and beat you with experience." ![Wink](images/smilies/windfk.gif) Mark Twain
