Old 11-03-2015, 01:21 AM   #9
Originally Posted by mckayprod View Post
ALRIGHTY THEN! Removed the tank and set the valves as per Spud. Learned a trick...take the feeler gauge out of the handle. It moves better that way. Set clearance tight with the .076 mm, and the .064 mm slid right in. Juggled all the hoses back into place and she started right up.
Thanks for all the help. I'll be changing oil and checking the chain tomorrow.
I'm glad you got the bike running again.
Yes, I always remove the feeler gauges from the holder. It is very important to do so with the smaller gauges, especially when used in cramped quarters.
