Ok, so followed your advice. Got the tank inverted and had a good look. One connector was a bit loose but dry and definitely not leaking. I cleaned and dried the underside then sat and waited.... Slowly a drop formed on the bottom edge of the tank. Upon closer inspection fuel seems to be seeping out from underneath the fuel tank next to where the main retaining bolt goes. Specifically from under some kind of strengthing plate underneath. Very slow but definitely a leak. Anyone e any ideas? I see CSC has tanks in Stock so I may just go ahead and order one. Thanks again for help
