Originally Posted by jct842
You might check under the flywheel to see if there is room to add a small winding. It really doesn't take a lot to generate 6v ac and a simple rectifier to make it dc. even if you could only make low current it would extend the ride time with lights.
There were some ignition upgrades i seen on a Yamaha Enduro site i was reading awhile ago. The bike is actually wired as such that has a lighting coil and can run without the battery. Well at least run the Headlight anyway..the rest of the lights require the engine to be revving a bit to power them.
After reading through some of Spuds threads again recently its got me debating my plans for tires for this bike. It doesnt weigh all that much so it wouldnt shred tires as fast as say an XR so im open to suggestions for good tires that would be good for both pavement and dirt. The trials type tires on it currently arent too bad on pavement but they can get a bit squirrelly on the loose and sandy dirt around here.
Past bikes:
'10 Gio X33
'85 Honda VF750F Interceptor
'80 Honda XL185S
'76 Yamaha DT250C dual sport
Baja Wilderness Trail 250
'07 Honda Shadow 750 Areo Trike
'01 Harley Davidson Softail Deuce
Polaris Magnum 425 4x4
Originally Posted by andyj812
You can't pin this one on me, my wife is still mad at me. I don't need your wife mad at me too. LOL
Originally Posted by 2LZ
Disclaimer: The above post by 2LZ is in no way the view of this site, other members or Bruce's llama. It is the opinion of 2LZ and 2LZ alone. ;-)
