Originally Posted by Mudflap
First things I would check is ignition and cam timing since it's been apart. One tooth off on the cam timing or a few degrees in the ignition timing could have the effect you describe. Also be sure the valve lash is set properly.
Excellent guidance! I'm not sure I would have thought of the cam chain so quickly.
