Been helping a friend assemble one (Assembly Pictures - whenever it gets done)
If you consider it a combination of:
Honda NX 150 (Engine [maybe] and Some electrical layout - Battery on right side)
Honda NXR 150 ESD (2009) (Frame, Plastics, Attachments, Front Disk, Rear Drum, non-applicable ECM controlled engine - Battery on left side as on Hawk)
Then some torque values are:
Front axle is 44 Nm
Top bolt of of front shock clamp 22 Nm (NXR 150 has side-bolt clamp, Hawk has front-bolt clamp)
Bottom two bolts of front shock clamp 32 Nm
Swing arm is 88 Nm
Mono shock is 44 Nm top and bottom
Rear axle is 93 Nm
Handlebar Clamps 26 Nm (dot on clamps pointing at front wheel)
Front disk brake caliper 30 Nm
Hope this helps.
