NOT going to make fun of you; we all started somewhere. I learn something on this forum every day.
Remove the carb, remove the bowl and then unscrew the brass main jet that is in the middle. What number is stamped on it? Is it totally clean inside? You can carefully clean it with some spray carb cleaner and a wire bristle from a wire brush.
