i bought the xr200r motor and it won't kick over I think because of the timing chain.Im going to pull it apart and see hopefully its in the top of the motor. well i pulled it apart and timimg chain was loose and it ate into the cam.Does this mean its junk? or Bearings are bad or whats up ? it took out the cam so that means it took out the valves to right? It won't roll over cause timing chain is preventing it. help!
