Old 08-23-2015, 05:22 PM   #3
Originally Posted by detours View Post
8000 miles ... you are my hero
As to the coolant ... could it be leaking inside the engine somehow? How's the oil level, smell and color?
The oil level remains constant. At every oil change the used oil is in excellent condition.
The coolant disappears slowly, so I don't suspect faulty gaskets. At first, I thought the left radiator had an air void from the factory, which needed to be refilled. However, after refilling the coolant overflow bottle many times, I now suspect Adjuster is correct.
