Old 06-08-2015, 01:21 AM   #6
I suggest you call CSC for the definitive answer to both questions. However, the EC Cami 250 Owner's Manual specifies the torque for the counter shaft (C/S) sprocket to be 55 Nm, which is 41 foot-pounds.
Are you inquiring about the screw which holds the air filter assembly together? If so, it might be included in part #9, the Air Filter Element Bracket.
http://www.cscmotorcycles.com/category-s/154.htm
