It's an Ironhead, the engine and trans share a case. Extremely similar to the shovelhead motor except for theddisplacement, shared case, and it has parralel push rods vs the shovel's V configuration. I've already pulled the tranny and confirmed that it will have to be rebuilt or replaced. My options range from $400 for a used one to over $1200 for a built Andrews transmission. Since the motor is well built and significantly more powerful than stock, and I don't want to strip any more gear teeth( I sheared off 6) I'm going to resuse the trap door and shift forks, and replace all gears and shafts with Andrews parts. Should run me about a grand before I'm done. More info and pics when I get the kiddos in bed tonight.
2004 United Motors DS200 "Denise"
Be Dragonized!
