Originally Posted by Bruce's
Have you checked to see if the carb slide is in correctly ?
Carb slide is seated correctly, that was the first thing i checked, throttle cable is working smoothly i had even installed a friends brand new makuni carb with the stock jetting to see if it was just mine and his did the same thing. Im stumped im thinking a possible vacuum leak?
