Old 05-06-2015, 03:24 AM   #9
Thanks for posting the tip regarding the split side panel covering the air filter.
I have not yet installed my panniers. However, after examining the motorcycles, I am confident there will be no problems accessing the top rear screw shown in the photograph. The only problem with access is likely to be the bottom rear screw on this panel, which is not visible in the photograph.
Since I currently don't have the proper bolt, I merely removed the bottom rear screw for the interim. The front portion of the split side cover is retained by a tab and two other screws at the top of the panel. Therefore, I believe the panel will be very secure without the bottom rear screw, at least until I can get the proper bolt.
