Originally Posted by Wolftrax
The CRF250L has recommended settings for stock, Stage1 and big bore. I think setting it up as stock will be the baseline. The CRF EJK only allows you to add fuel. I noticed that the EJK for Delphi equipped HD's allows for adding as well as subtracting fuel. More than likely I'll probably open up the airbox and knock the cat out if it has one.
Here's a photograph of the RX3 air box.
The foam air filter is rectangular, as shown in the following links.
http://item.taobao.com/item.htm?spm=...cket=19#detail
I seems you unscrew four bolts, and slide a rectangular, air filter assembly out of the air box. After cleaning the foam air filter, you install the foam into the rectangular holder, and slide the air filter assembly back into the air box. Then you screw in the four bolts.
Air enters the rectangular opening above the air filter holder. I assume we can trim some of the top from the rectangular opening. We could also install some wire mesh to cover the hole on top of the air box.
"Never argue with an idiot. He will drag you down to his level, and beat you with experience."
Mark Twain
Mods made to my Zongshen ZS200GY-2:
http://www.chinariders.net/showthread.php?t=6894
