Ok here it is in pictures!
This is the ATV we obtained. It was originally Blue. A headlight is missing, the tail light has been cut at the light. The starter relay sits outside the frame on top of the CVT. The Ignition switch wiring is hosed and already hacked. The wiring from the starter is bad as well. They did manage to get it started while I was standing there which is when I noticed the acorn nuts to the exhaust are missing. Oh and of course the seat is super shot. The places where you put your feet used to be webbing but are rotted out. The airbox was wedged in there turned 1/4 from the way it should have been and the carb clamp is missing. The grips need changing as well. There's some hoses that are just broke and hanging in air so I'll have to investigate that. And the Right hand Flywheel Cover is missing.
So that's the short list. The future of this ATV has racks on the front and back, front headlights, a trailer hitch, and a winch. Tah Dah. I also want to change the 40t sprocket for something bigger to make this more of a hill climber/slower ATV too. Speaking of it'll need new tires as well.
There we are. Now for some preliminary pics:
2008 Zongshen 200GY-A, HS163FML : Needs: Battery, Battery Box, Both clutch and brake handles, exhaust system, all plastics, gas cap, starter rewired. Her name will be Phoenix.
2007 Shineray Speedee 150, 1P57QMJ: Needs: starter rewired, exhaust connected, cleaned up, ignition switch simplified, new seat and lights, new front and back racks.
There's no such thing as a free puppy or motorcycle. I think I have caught the fever from y'all.
