Old 08-26-2013, 08:13 PM   #10
Tvnacman   Tvnacman is offline
Send a message via Skype™ to Tvnacman
Originally Posted by shortyg83 View Post
Ok just bought my brother a Tao Tao 50cc scooter, its a ATM 50-A1.
He is trying to make it a little faster if possible.
Can anyone give me an idea of what is needed to do so?
I would start under the cvt cover , some 50cc come with a washer in between the variator pulleys . Some call it a restrictor , what it does it stops the variator pulleys from closing all the way up , and the opposite for the clutch pulley . This maybe a no cost no parts tweek/mod . You will need an impact gun to get it opened .
The fan pulley is larger diameter then the inner pulley , you can get a larger diameter variator pulley(inner) . Beyond that you can start with roller or slider weights .
Changing the muffler and intake will require jetting adjustments , this can get very tricky . BBK's work well but will not get you anymore topend without gearing changes .
I see this thread is a few weeks old I hope you see this in time .
John
http://www.nycscooterparts.com/
For tech help call John 2125980016
