The trouble I'm having with gearing is that I'd like to have options to go both higher and lower than my current setup. I have a tired 24t on the back and feel that a 26 would be nearer the mark for most tracks.
Because there is not much size difference between the front and rear one or two teeth on the back makes quite a big difference. Going up on the front and back will give me ratios that lay in between just going up in 2t increments on the back alone.
In addition the 24 I have on the back seems to be very rare and all I can find to fit a 30mm kart axle is 26/28/30 etc nothing smaller, so a bigger front would bail me out a bit.
Hopefully tomorrow or thursday I will get the chance to pull the cover off and have a closer look to see how much room there is.
So is there a common mass produced front sprocket fitment that will go on my zonger? Seen some Yam ones that look the same but havent laid my hands on dimensions yet
