Originally Posted by david3921
As far as I can tell, both the DR and XF/XP baskets are the same. The Moose filter is a lot firmer and slightly thicker so it's a bit more difficult to get everything lined up while trying to screw in the wingbolt (good one 2LZ).
As for oil, there was none on the original nor any instructions with the new filter. I didn't put any on as I thought with the increased surface area, and quality, that I wouldn't have to worry about poor filtering.
Hey, Weld, why do I have 30.5mm written on my hand?
You definitely want to oil it, the foam by itself will only stop the big stuff. I use No Toil, the alcohol based stuff. You can get complete kits with the cleaner, the oil and even gasket grease. I bought a bulk container of the No toil (2 litres) and I just use Oxy Clean to wash the filter. No more nasty solvents... You just have to make sure it's good and dry before you oil it.
