lifan dirt bike manuel
hi i have a lifan 125cc 4 up engine i need a manuel or some info i dont know what to adjust the valves to this is all the specs....or if you know a shop i can get one off line thanks for your time..
Lifan 125cc Motor Dirt Bike Engine 4 UP!! 100% GENUINE LIFAN 125CC BIG BORE AIR COOLED ENGINE With all new 4 UP system. Limited Time offer!! Description: Brand New LIFAN 1P54FMI 125cc high performance race engine. Upgrade your stock 50cc to this 125cc monster, you can feel the power difference immediatly. Ride faster, jump higher. LIFAN offers with this engine of the newest generation all tuning- and racing-fans best quality and highest performance state-of-the-art! The engine comes with a high-qualtiy cylinder head made from aluminium, a reinforced kickstarter axle and extra large valves and canals! Furthermore it comes with a high-quality 4-disc clutch! With 7.4 kW by 7500 rpm the engine reaches more than the triple performance of a standard CRF50 engine. Specifications: Single cylinder, 4-stroke, 2 valves, OHC racing head, air cooled, 125cc Bore x Stroke: 54mm x 54mm, this is a 'square' engine for best balance between power and torque Dimension: 17"X11"X9" Valve Sizes: 27mm intake, 23mm exhaust Displacement: 123.7cc Compression Ratio: 9.47:1 Ignition: CDI, 12 volt, permanent magnetic stator Maximum Power: 8.5 Kw DIN @ 9,500 rpm Rated Power: 6.5 Kw @ 7,500 rpm Torque: at least 8.8 Nm @ 5,500 rpm Gears: 4-speed, manual clutch, All new 4 up System. Gear Ratios: 1st 2.833:1, 2nd 1.706:1, 3rd 1.238:1, 4th 0.958:1 Final Drive: 14 tooth #420 front sprocket included (we have other sprocket on sale too!!) Lubrication: 1.1 litres, 5W/40 4-stroke motorcycle oil, pressure and splash Fuel: Unleaded Package Contains: Buyer will receive Lifan 125CC Motor, Intake manifold, intake gaskets, Shifter, Kick Starter and Spark Plug. This Motor should fit the following models: Note: This is not a guarantee, if you are unsure, please check with your local dealer. HONDA CRF50 / CRF70 / XR50 / XR70 / Z50 / Z50R / CT70 Mini Trail / Z50 / Minitrail Monkey / XL70 ST70 / QA50 / QR50 / CL70 / SL70 / 70 Passport / ST 90K2 / ST 90K1 / CS 90 / SL 90 / ZB 50 / Free Image Hosting at www.auctiva.com (GENUINE LIFAN NOT KNOCKOFF!!) Free Image Hosting at www.auctiva.com Free Image Hosting at www.auctiva.com ( KICK START, SHIFTER and MANIFLD included!!) |
thanks very much do you know were i can get a manuel
Try here:
http://www.vankeulen.tzo.com/CT/Stuf...2078-82%20.pdf This gives you a shop manual for a Honda CT-90 1977-79, CT-110 1980-82. |
thanks but i need a lifan manuel that engine dose not look the same :D
