Megadan |
07-09-2023 10:40 AM |
Originally Posted by Bikenut
(Post 397247)
I am not an oil expert! The following is just what I've learned/read/been advised during 50 years of riding.
Oil change intervals really depend on how the bike is used. Guys or racers who run at high revs all the time should change oil more often than the guy who just rides normally. Those who ride in very cold areas should change more often than those in temperate areas to avoid condensation buildup. Those in very hot areas should change more often because excessive heat breaks down oil faster.
The oil change intervals in the air cooled bikes I've had in the past depended on usage. If I got caught in traffic in hot days I'd change oil more often than 3000 miles. Dirt bikes oil got changed very often. What is "very often"? Depends on how hard the bike was ridden in what length of time. Could be a couple of months and could be a week.
On my liquid cooled 2020 400 KRT Ninja and 2021 Lifan KPR 200 I use any brand 10w40 mineral motorcycle oil and change oil and filter every 3000 miles. The Ninja has 15,000+miles and the KPR now has 10,000+ miles and both are running just fine.
I second everything said here. Change intervals will depend on conditions and how the bike is ridden. I don't go off of a mile interval, but by the feel and smell of the oil. At a bare minimum I will change the oil once a year if I don't manage to ride the bike very much, such as last year where I only put a few hundred miles on it.
The oil cooler made a big difference for my bike and the way I ride in making the oil last a lot longer. I ride my bike about 70% of the time at sustained speeds between 45 and 65mph, which is where the oil cooler does the most good, especially once I start pushing it above 55mph where the motor is working hard. If you do a lot of slow speed riding the oil will still get heat soaked even with a cooler because of a lack of airflow, and this will affect the longevity of the oil.
Just a fun fact related to this topic. CSC states 2500 mile oil change intervals for the TT250. These cheap little engines are also based on the CG125 design, which was designed around the concept of being in environments where they wouldn't get regular maintenance. Basically designed to still survive even when working with dirty crappy oil.
My VFR1200 engine has factory recommended intervals of 7500 miles with standard Honda GN4 oil. I don't go that long with it lol
