Brozz Rear Brake Pads
2 Attachment(s)
Anyone have a link for Brozz rear brake pads on Amazon? I purchased these and the front work but the rears do not.
MOTOKU Front Brake Pads for Commander 800R 1000 Maverick 1000R Mule Pro Fx Fxt Bayou 300 400 Teryx 750 4 800 Brute Force 650 750 Rhino 450 660 700 https://a.co/d/384EUkH Here are the pics of the single piston pads on rear see attached I think it might be this one found on Amazon but want to ask the audience before I take a shot in the dark GOOFIT Disc Brake Pad for 50cc 70cc 90cc 110cc 125cc 150cc 200cc 250cc ATV Dirt Bike Mope Scooter https://a.co/d/33ryVAq |
Circling back with an update. The pads i ordered from Amazon fit but were not right as one side sat high while the other low. Will be returning. The stock pads are: CD-F001 and are only found from my research on Aliexpress or Shopbrozz sites
A little searching and I ran into this. https://www.scooterdomain.com/ebc-br...gle-brozz.html
Looks to be the same as the ones on your bike. |
Thanks, that's good info for those seeking aftermarket alternative.
Circling back with a final update.. i wound up buying the rear pads from Peace Sports as none of the online options were exact match, at least not the ones i tested.
After fitting the pads, the original issue of weak rear brakes was still apparent and i further found that the pressure would be lost intermittently, indicating an issue with the master cylinder. Today i received the replacement rear master cylinder i found on Amazon that looked like a match, installed it and bled the system.. problem solved and she brakes great now Link to rear master cylinder: https://www.amazon.com/dp/B09ZP94XZ1...roduct_details MWMNUN Universal Rear Brake Master Cylinder Compatible with 70cc 90cc 110cc 125cc ATV/Chinese Dirt Bike/Yerf Dog 150cc Arctic Cat 700 EFI 2006 Roketa Taotao Yard Card 150cc Go Karts(GOLD) I did have to make some modifications to get it fitted.. added a metal plate to attach to the stock mounting bracket as it sat too high, and then re-routed the filler cap to the carb side of the intake box |
