ZS190 Swappers!
Anybody want to sell me their old motor? I've tried replacing the jug on mine, but after having problems with things fitting, I just want a new motor. I live in Maine, would be willing to pay plus packing and shipping fees.
I will be doing the swap but won't happen for several months. U can get new engines for a little over 200.
I have a 125cc motor off my 2017 SSR Razkull I'm looking to part ways with now... has about 2,000 miles on it. Broken in properly, oil changed every 300-400 miles with Mobil 1 Racing 4T 10W-40 motorcycle oil. Oil filter screen pulled and cleaned every other oil change. Will throw in an extra brand new clutch cover gasket from tbolt usa.
It's a three bolt pattern design just as a Honda grom has, may want to double check but you will probably need engine brackets to use this in a clone (Boom, Venom, Vader, etc.) Shift pattern is 1 down, 3 up. 16T sprocket on it. PM me if you're interested! |
Where did you find the 190 for $640?!?!
https://imgur.com/94xwh3X.jpg |
if that coupon code stops working you can always use "miked" at check out...comes out to $743 w/ shipping |
Would highly suggest changing the swingarm with something stronger if swapping to the 190. I put a Grom swingarm on mine and replaced the rubber bushings with the brass ones from mnnthbx.com
