Damaged Spark plug
2 Attachment(s)
About 30 miles into my 35 mile commute home from work today my Storm stopped running and would not restart. After pulling out the plug, I found it to be very damaged. Has anyone ever seen anything like this before or know how it can be caused? If I am lucky the metal either blew out the exhaust or is in the bottom of my oil pan but I am assuming a piston ring job may be in order.
Was there a crash or something? That plug looks really chewed up top to bottom?
If the plug is that damaged, I would say the piston and cylinder head are also screwed.
That ain't good.:ohno: Pull the head and see what damage was done. I,m wondering if you had a screw or something in the air box it sucked in through the carb? Check the carb and see if screws or even if the butterfly choke valve is still there.
It's my opinion this should be covered under warranty.
The last time I saw that it was a dropped exhaust valve head that turned sideways and shut down the engine quick. There was no rev down. He was buzzing along then immediate silence. The valve head was embedded in the piston. When we sorted it out after cooling, we tried to start it and nothing. It made no funny noises or anything. Sounded just like it was out of fuel when we tried to start it. I could see the valve in the piston by rotating the engine with the kickstart and looking down the plug hole. My eyes were better 25 years ago.
HOLY SMOKE that is bad.
I bought one of these a while back and you will be able to do a cursory inspection without removing the head. It has 5 little LED lights on it and works great. You can get them cheaper on ebay but have to wait longer for shipping. https://www.amazon.com/DZT1968%C2%AE...70_&dpSrc=srch |
A alloy piston is not going to do that sort of damage to a steel plug...
so my thought is something steel has gone though the motor.. start looking for missing bolts/nuts etc on the intake side of the motor.. Maybe it's still in there......the piston won't be a pretty sight... might pay to lift the head... ... |
"LG" (蓝光牌) is made by 重庆市南迪火花塞制造有限公司. That company located at the SAME city as bike/ small engine "hub" which very few retails in bike shop/ parts house. ;) Nobody want that shite ruin their biz...
Infamous "torch" http://english.torchsparkplug.com/about.aspat at least is soild . For those short of ¥ = so-so product from Hebei/ Zhejiang ... |
I am thinking it may have melted and possibly melted through the piston. Will find out when I open it. Wishing I had that endoscope. |
Tom, you can pop the valve cover off and slowly turn the engine over by hand (or with the kicker). If both valves actuate properly, you'll know the damage wasn't the result of a dropped valve.
I'm with HB; my guess is the plug grenaded. |
3 Attachment(s)
Look like my piston melted. Exhaust valve is gone.
OMG! That's something I've never seen, It's completely obliterated. Thats looks like something that should be covered. Have you contacted the seller?
He also told be he would work with a professional shop for the parts If I want to bring it someplace for repair. I did call a shop in my area. http://www.procyclevt.com/. I was politely told that it was not personal to me but they refuse to work on a Chinese, or any 'off brand' bike. He mentioned an bad customer experience but I assume there is some animosity considering he charges thousands more for used bikes. In actuality, this only took a few minutes to tear down and seeing that I won't need to split the case, it's going to be quick to repair. |
