headlight goes out
if i am lazy switching from high to lo beam or vice versa my lights go black the switch gets caught in the middle and everything goes black is this part of owning a Zong or do i need a new switch no problem with a positive flipping of said switch just wondering if anyone else has had this happen if it's just a quirk i can deal with it thank you all WILLY
Willy, I would just operate it like you mean it. There is probably a "grey" area in the switch that is between high and low beam meant to totally disconnect the current so that it doesn't turn both beams on at once and cause a surge in current and blind and erase the childhood memory of someone .:lmao: I've found that I can make most things fail if I fiddle with it long enough. Mine does the same. Others ??? rj
It's not your imagination; mine feels the same way. When I was having headlight burnout issues that little gap really made me nervous because I ride in REALLY dark places! Search the forum for Spudrider's Headlight Switch Repair post for one man's solution. I'm just going to live with it, but I don't like it either.
don't worry from now on i will be switching back and forth with a purpose this morning for 1sec when everything went black was not a feeling i want to experience again right where the deer like to cross too:thanks:
When I realized that my headlight switch had developed a "dead" zone between low and high beams, I was able to get a replacement switch from CSC under warranty. I have not yet installed it, since the problem has not gotten worse. And I can tell if the headlight is on by the light that gets reflected along the bottom of the windscreen. If I don't see the light at the base of the windscreen, I jiggle the switch until the headlight comes on
Main point is to recognize you have a dead spot and not ride with the headlight inadvertently off. But this is one of the niggles I wish Zongshen would fix. |
Mine does it too if I move the switch too slow between high and low beam.
I had to replace the switch on my TT250 for the same reason. The TT uses the same assembly as the RX3. It wouldn't work properly unless I exerted some sideways pressure when I switched from low to high beam. Then it stopped working altogether.
On the plus side it was less than $40 shipped and arrived in three days. So CSC really does have all the spare parts in California. Cheers, Dan K. |
