Hawk engine swap ideas?
I Was wondering what type of engine would fit in the hawk. I've seen a thread before on somone swapping their engines with a actual yamaha one, in which i was wanting to do the same, as well as use a 450cc instead of a 250. It should be something that just bolts right up and only needs minor work. Does someone have an idea of what type of model the hawk is a replica of?
WildAlaskan put a Honda 450(?) motor in his Lifan years ago. By no means a bolt-in but wow...it was fast for a while! Strange seeing a GY5 stand it up on the rear tire!
I'd imagine you'd have to go with a Honda-something, just because that's what the original motor is cloned after. |
http://www.chinariders.net/showthread.php?t=15995 http://i442.photobucket.com/albums/q...ps3wuhphf7.jpg I don't know what engine, if any, might fit your Hawk. However, I'm hoping someone will chime in with the information you seek. :) |
I'm really wondering the same thing. I'd love to put something around 300-400cc on it. I could probably find an older bike at a junk yard or something, but I just don't know what could bolt in to the Hawk frame. Anyone knowledgeable with this that would know what motor to look for?
I just can't see spending the time on a CB to do an engine transplant.I can usually find a good used Japanese bike for the same money.I'm a tinkerer,and that's why I like the CB's.Not enough to do an engine swap.If it's a direct swap in, and gives some benefit other than to much power for the design,I'm all for it.
The frame or architecture is the same as the XR/XL 185and 200 (as Jeffrey says), and the CRF230 would also bolt in. That's it for bolt-ins. Anything bigger would take a welder. I wouldn't hesitate to adapt an XR400, XT350 or DR400.
B-40
While that was a tongue-in-cheek suggestion yesterday, I was remembering that the B-40, being a short stroke engine, might just fit in there. 350 cc means much more torque. And this engine is pretty mildly tuned, so has a wide torque band. Be happy, you guys. I was originally going to suggest an iron-head Sportster engine for this project!
Now ...Lester go scrape up that 400 :clap:
A Welder and Grinder and whatever motor is the best deal.... :)
I can always find someone though that already has a welder and grinder. |
