help identifying atv
2 Attachment(s)
other things that may help is engine says 167ml on it and vin says its 2005 from china (asia)
Welcome!
Please show us a pic of the engine and the rear axle. |
The neutral reverse indicator cover is on upside down.
Same part as my sunL though |
3 Attachment(s)
one of my main problems im haveing is i cant get starter motor reduction gear to fit in the large gear is to big probs last owner didn't fit the right part
Water cooled CG250 motor. Try searching eBay for CG250, and see what comes up.
1 Attachment(s)
thank you and for my next question if thats ok i need a new reduction gear i think it is called as my starter didnt work so i bought a 9tooth starer motor but now my reduction gear wont fit and the bearings are missing on the gear Attachment 2224
Std CG 200 &+ uses 11T starter motor ...
http://mall.mxjidian.com/?de=goodsdetail,gid--100027 |
I Need a new reduction gear all ready nought a new 9t starter motor
1 Attachment(s)
Attachment 2227 only problem is i live in uk so cant find supplyer
Worst case can bought from China. http://item.taobao.com/item.htm?id=26437344913 |
Hello thanks for your help what starter motor should I use on that set up 9t or 11t ?
Std CG125 is 9T http://mall.mxjidian.com/?de=goodsdetail,gid--100054
Hi thanks that's what I bought so once my gear is here I can get quad running and then rebuild her to her formal glory I hope :thanks:
