removing gunk from the gas tank
Hi, I know this not a new thread but I could not find nothing about how to cleaning a gas tank that has been sitting for years. I bought a Honda gas tank (not sure the model) and has gunk and is rusted. I know some riders use muriatic acid, vinegar, or distilled water. I would appreciate the link for my doubt or any cheap and effective suggestion. I will post some pics latter.
Cheers |
Dave had good luck with vinegar (might have been apple cider vinegar), and I've also heard good things about molasses.
I've used an environmentally-friendly chemical that is designed to remove lime, calcium and rust. It worked very well for me. |
HB, I took the time to read both of the forum threads you provided, and it seems that they're using the reverse-electrolysis method that is similar to what I use, except that I use sodium carbonate.
What I never thought of before, is that they followed the process with Coca-Cola and heat. What is the reason for that? |
They wants a clean surface for the "Phosphate conversion coating" liquid. |
Regular white vinagar. Or apple cider vinigar. They both work but apple cider is faster.
Depending how bad it is adjusts how long you let it soak I think I did my tank for about 72 hours then power washed the insides. Regular hose pressure would be more tgen enough though. Dave |
Here are some pics of the gas tank (I think is a Honda). I found it sitting in a junk yard for $15.
http://i123.photobucket.com/albums/o...ps795898b1.jpg Way too big compared to the stock one. I will figure out how to install it. http://i123.photobucket.com/albums/o...pse9070d95.jpg Does anyone know the model and capacity. I think is bigger than 3 gallons. http://i123.photobucket.com/albums/o...psc4f24223.jpg I will drop by the junk yard this week to get the gas cap. The owner has more than 50 different gas tanks and hopefully I will find the cap. |
That gas tank looks good. :) Make sure the forks don't hit the gas tank when you turn the handlebars all the way in either direction. ;)
What happened to the cover over the air filter? |
My guess is a Honda XL tank, that is for 250cc or bigger.
