Old 03-18-2016, 03:48 AM   #46
Riley W   Riley W is offline
So I did get the kart running but I forgot about the ignition switch that I bought, I don't really know what to do with it because I connected it to a colors-matching plug and forgot about it. When I turn the key it doesn't do anything (which I expected since I have no computers or anything hooked up) but I just installed a trail tech vapor and I want to be able to turn the key and make the led on the vapor's screen light up. How do I do that?
Old 03-18-2016, 03:52 AM   #47
I did order a air filter, but I didn't know I had to do more with the exhaust, do you mean weld a muffler on (because I have one to weld) I don't really want it quieter, do I have too?
Old 03-18-2016, 04:39 AM   #48
Adjuster's Avatar
Yes an exhaust causes restriction. You need the correct amount of air going in and the correct amount of air going out so to speak. No need to weld, there are many bolt on exhausts available. You just need to get one for your correct engine size.
Old 03-18-2016, 04:45 AM   #49
I already have an exhaust header on
Old 03-18-2016, 05:08 AM   #50
pete   pete is offline
pete's Avatar
Originally Posted by Riley W View Post
wait, so i wouldn't even have a starter solenoid? i would just a have switch connecting the starter motor wire and the positive battery lead wire? in my case the black and red wires.
being a kart... you could do it that way...
you will be surprised how meany amps that
little starter motor will draw...
need a big ass non latching button switch to
carry the amps.... and heavy wires...very heavy..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 03-18-2016, 05:20 AM   #51
I'm going to call the place where I ordered the engine and try to get a different wiring harness because I looked at their website and they sent me so many different colored wires and terminals compared to the pictures on their website, kinda pissed since I put so much work into it and I am not experienced enough to tell this was the wrong harness. This does mean I'll just use a relay and not risk problems with amps and stuff
