Old 07-06-2009, 09:47 PM   #31
katoranger's Avatar
Check out this video.
Excellent job showing all the parts and explaining things.
Old 07-07-2009, 03:35 PM   #32
yozalo   yozalo is offline
Thanks katoranger. The video was very good and informative. I will clean my carb out.
Old 07-07-2009, 05:48 PM   #33
katoranger's Avatar
While you got it apart take a look at the little numbers stamped on the jets. That will let us know if maybe you are overjetted.
Allen
Old 07-07-2009, 08:19 PM   #34
Yea, will do katoranger. Thanks for ya help. 8)
Old 07-09-2009, 05:41 PM   #35
TurboT   TurboT is offline
Wondering if you got this baby running hot yet?
Old 07-09-2009, 06:42 PM   #36
No, not yet. Were goin on vacation soon so I didn't bother. Anyways, I got my butane torch.
Old 07-14-2009, 06:35 PM   #37
UPDATE: The problem is fixed I turned the mixture screw 3/4 turns to the right to make it more lean.
Old 07-14-2009, 06:56 PM   #38
Glad to hear you have it sorted so you can enjoy the speed!
Old 07-14-2009, 08:56 PM   #39
Ehhhh... nope. Looks like another problem. :evil: When I ride my atv and go to 1/2 throttle it starts to bog after awhile. Then I let go of the throttle and the atv shuts off by itself. Don't know what the problem is. Maybe I should clean the carb or something.
Old 07-14-2009, 09:00 PM   #40
what position is the choke when this is happening?
Old 07-14-2009, 11:15 PM   #41
The choke is in the middle.
Old 07-14-2009, 11:33 PM   #42
My daughters would bog a bit when it was new once it warmed up and the choke was in the middle, especially on a hot day. You might need to let it warm, then close the choke out some. Just a guess.
Old 07-15-2009, 12:20 AM   #43
I was going to say the opposite. Once the engine is fully warmed, you should be able to open it fully.
Old 07-15-2009, 12:43 AM   #44
Or you could try both and see what happens.
On mine, pushing the lever away from the motor under the handlebar made it run better. I never actually looked at whether it was opening or closing, just assumed it was closing.
On thinking, hot day, warm air less oxygen, so need open choke to let more oxygen in.. could be W&G is right yet again. The mechanical "go-to guy" ..
Old 07-15-2009, 11:30 AM   #45
Tks, I will try both methods. Also I'll play with the idle screw since it is idling hard.
