Thread Tools Display Modes
Old 09-26-2008, 03:23 PM   #31
pizzarider   pizzarider is offline
Originally Posted by Jim
Did you check that all the wires are still soldered on good to the back of the light socket?
I will check. Thanks -Cory
Old 09-26-2008, 03:30 PM   #32
A new problem,
First time I tried to fire the bike up after my flat repair via electric start the starter wouldnt work. Every time I push the electric start button i here a "click" under the seat behind the air filter. ?? -Cory
Old 09-26-2008, 03:53 PM   #33
Cal25   Cal25 is offline
Low battery maybe? A really cheap volt-ohm-meter would be your best friend about now.
Old 09-26-2008, 06:13 PM   #34
blinkers and headlight work great. -Cory
Old 09-26-2008, 06:36 PM   #35
alonzo   alonzo is offline
does the electronics all zonk out when you hit the starter?
If so clean ALL battery connections from the battery to the solinoid battery to frame and so on.
Old 09-26-2008, 07:10 PM   #36
All of the other electronics are fine when i hit the starter button. Nothing dims or anything. -Cory
Old 09-29-2008, 01:51 AM   #37
I now have 2500miles 4000kms on my HSUN 200gy. This week has been difficult with the rear tire. Last week i had a flat and had to get a tow and then saturday afternoon I had another flat with a NEW tube! There wasnt any puncture through the tire at all!! I was delivering pizzas when it happened and somehow got a hold of a motorcycle shop that was open on saturday and got a new tube. One of the guys at work came and picked me up with his truck. Got back to the store and did a tube replacement. I noticed on both of the tubes that went flat, a sort of a small scrape with some punctures on the side of the tube. Wondering if maybe there is something in the tire causing this. Tomorrow I am going to take my newest tube out to see if I can spot the problem. -Cory
Old 09-29-2008, 06:28 AM   #38
katoranger's Avatar
Inspect the inside of the tire for debris and also the inside of the rim.
Allen
Old 09-29-2008, 09:15 AM   #39
Maybe it was "pinched" while putting the tire back on the rim?
Old 09-29-2008, 07:40 PM   #40
warrior91   warrior91 is offline
Originally Posted by pizzarider
A new problem,
Swap out solenoid...try tapping solenoid while starting first...
'91 Yamaha Warrior- stage 2
'83 Honda ATC 70
'08 Yongjiang 125cc mx (Loncin)
'08 Yongjiang 150cc atv (Jinlong)
Old 09-29-2008, 07:55 PM   #41
A new problem,
Ok will try. Thanks -Cory
Old 09-29-2008, 07:58 PM   #42
Dont think it was pinched cause 3 different tubes (including the original) had a scrape in the exact same spot. I ran my hand through the whole tire and felt nothing and ran my hand over the inside of the rim and didnt feel or see anything. I did notice that the "scrape" isnt on the inside part of the tube that touches the rim, it is only on the part that the tire touches. -Cory
Old 09-29-2008, 10:40 PM   #43
Ok, I tried tapping on the solenoid but it just will click one time every time I push the start button. The wires all look secure. As for my tail light, I did find the problem. Looks like the green/yellow stripe wire and the brown wire came undone. http://chinariders.net/gallery2/main...serialNumber=1
As for my tube... I felt the entire inside of the rear tire and didnt feel anything that would have caused the scrape. It doesnt seem like the scrape is on the part of the tube that touches the rim. Here is the picture.
Old 09-30-2008, 08:33 PM   #44
So I need a Solenoid for my HSUN 200gy. That is the reason my starter wont start. Does anyone know where to get one? Thanks -Cory
Old 09-30-2008, 09:13 PM   #45
If your in a hurry, try one for a lawnmower. Should be about 10 or 15 bucks and easy to find. May have to get creative mounting it. Others will chime in as this seems to be somewhat common.
