Old 04-13-2016, 06:20 PM   #31
BARLOW   BARLOW is offline
BARLOW's Avatar
Originally Posted by Riley W View Post
I didn't notice I had to pull in the clutch when I brake, I'm totally ok with that, for my setup what do you suggest I do.
if this was my cart, i would put a clutch lever on the shifter, so you squeeze the clutch as you shift, but others put them on the steering wheel, like a paddle shifter
Old 04-13-2016, 06:21 PM   #32
BARLOW's Avatar
Thanks I'll tell you what happens in a bit
ok man, good luck
Old 04-13-2016, 09:05 PM   #33
Riley W   Riley W is offline
Unfortunately I got no result from engaging the clutch. When I pulled the clutch in really hard and braked, the engine died
Old 04-14-2016, 11:51 AM   #34
Should I get my clutch replaced?
Old 04-14-2016, 12:39 PM   #35
BARLOW's Avatar
no, it is not clutch plates or disks ... there is still something out of adjustment ... you may even be missing something ... can you locate a friend that knows about clutches, i cant do much from here to help
Old 04-14-2016, 01:49 PM   #36
yea ill take it to a motorcycle shop, thanks so much for all the help
Old 04-14-2016, 02:45 PM   #37
BARLOW's Avatar
no, the plates and disks seem to be working, you may be missing something, or something still needs adjusted inside ... try to locate someone that knows clutches and can help you open it up ... is it new, it may be under warranty
Old 04-14-2016, 10:30 PM   #38
I actually can't take it too someone but it seems pretty simple if you can guide me through diagnosing the clutch, I took a video of the inside of the crankcase. This is my first real engine I've ever worked on and I'm 15 so I can't really understand what's wrong with it because I haven't ever seen one before.
Old 04-15-2016, 11:49 AM   #39
bump.
Old 04-15-2016, 02:47 PM   #40
Bump
Old 04-15-2016, 07:11 PM   #41
i know how to clutch works in my engine but i dont know whats wrong with it, pls help.
Old 04-16-2016, 10:11 PM   #42
Bump
Old 04-19-2016, 02:16 AM   #43
Bump
Bump
Old 04-19-2016, 08:59 AM   #44
Bruce's   Bruce's is offline
Your clutch basket is definately too loose ,can't see enough from your video to tell what else might be going on .You need to figure out a way to hold the clutch while you remove the nuts ,a strap wrench ,a chain wrench ,a large set of channelock pliers ,putting it in gear with the wheel on the ground to keep it from moving ,etc ,you are a pretty smart guy with what you have figured out so far ,this should be easy for you .
Is this engine brand new ?is there any warranty ?you might wish to send it back and let them deal with it if it's above your pay grade ,but learning is definately more fun .
Old 04-19-2016, 03:29 PM   #45
yea i dont really want to send the engine back, i think its best for me to learn about problems and fix them, i have dreams of restoring a 69 camaro and i want to learn as much as i can before a get the car so im not completely clueless. I already took the four bolts off and springs with a electric torque wrench, but i ran into a problem with that other thing next to the clutch (I don't know what its called) its overlapping the clutch disks and plate, i cant remove it without removing the thing next to it. I already tried removing the thing next to it but after i took out the screws with the torque wrench, there wasn't a clear way of removing the rest, and i gave up right there because i had other things to deal with, I've been just cleaning up the frame for now, what should i do regarding the clutch and the thing next to it? I can send another video today showing the point that i got to until i gave up for the day. Should I?
Thanks again Bruce, nowadays you cant really get education about automobiles and engines and this website is great for just that.
