Old 05-16-2015, 07:05 PM   #31
humanbeing's Avatar
Thanks, HB. Have you seen a 70mm cylinder kit for an air-cooled CG?
NO, cuz nobody wants to kill their trusty old (The newer model http://bbs.360che.com/viewthread.php?tid=560445 is water cooled) workhorse.
Old 05-16-2015, 08:26 PM   #32
JohnWayne007   JohnWayne007 is offline
A 70mm bore and 65mm stroke becomes an honest 250cc, without rounding up (like most manufacturers do). I might grab a kit like that for a project I have in mind.
Please start a thread on your friend's CG, when you blow it apart for paint.
i will for sure start a new thread for the tear down and paint. im sure lots of people would be interested in following it!
i have had another issue with my bike today, i went to start it (kick start) and i noticed that my Electric start was trying to engage while doing so. but the really weird thing is my electric start is not even hooked up, the positive and negative wires are not attached to the bike (electric starter clutch is toast) so the kick start is my only method of getting it to start and i just found it extremely odd that everytime i kick it, the starter motor makes noise like its spinning. makes no sense at all
Old 05-17-2015, 01:18 PM   #33
I've heard that noise on occasion. My guess is that the one-way gear is sticking a bit.
Is your friend's CG liquid cooled?
Old 05-17-2015, 01:25 PM   #34
His CG is also Air Cooled aswell, an regarding the sticking one way gear, do you think a CG over-running clutch would work on a CB engine? ive been looking at purchasing a new one but all ive been coming up with is the CG one
Old 05-17-2015, 02:00 PM   #35
I haven't compared them, but I'd say probably. Do you have a CG over-running clutch that you can compare with? You've torn into CG motors more than I have.
Old 05-17-2015, 02:44 PM   #36
Visually they look to be the same, my friends CG over running clutch is also bad so i may just wing it. Order one and put it on my CB after comparing the new with the old and if there is a difference and does not work on mine atleast it will on his. I was concerned because i wasnt sure if trying to kick my engine over and having the starter motor spin at the same time would be good for it
Old 05-17-2015, 02:59 PM   #37
humanbeing's Avatar
OHC http://item.taobao.com/item.htm?id=7475053185 http://item.taobao.com/item.htm?id=20539416428
Generic : http://item.taobao.com/item.htm?id=44549024473
Old 05-17-2015, 03:43 PM   #38
thank you humanbeing! your a life saver i searched everywhere, i also found this https://multinationalparts.com/produ...784/pictures#3
do you think that would be the same as well? the only thing so far it has is the same number of teeth, and it says " most commonly used for 150cc to 250cc automatic ATVs, dirt bikes, and buggies/go-karts" if i have to i will order from taobao but if i can get the part locally or in canada that would save a lot of time for me. this part is something else to me as Ive never really had much trouble with these parts in the past so Ive never actually had to change one or look into them i knew what they were and do but that was pretty much it.
Old 05-17-2015, 07:05 PM   #39
humanbeing's Avatar
Originally Posted by JohnWayne007 View Post
thank you humanbeing! your a life saver i searched everywhere, i also found this https://multinationalparts.com/produ...784/pictures#3 ...
3 rollers ONLY!!! How long will it holds is a BIG? The "generic" above TELLS this as in 125/150
CB250
16 rollers (More durable than stock 20 rollers...) http://item.taobao.com/item.htm?id=20539416428
GEAR
http://item.taobao.com/item.htm?id=9828490459
CG
Universal "9" http://item.taobao.com/item.htm?id=43396471632 or the original type ...
Old 05-17-2015, 07:48 PM   #40
CB250
GEAR
CG
Once again thank you! i wasn't too sure how many rollers it had i thought maybe it was just some sort of protective casing or something. Like i said these parts aren't really in my area when it comes to fixing things so i wasn't sure. i will most definitely be putting in an order through taobao and i may just order 2. i plan to keep my bike for a very long time so it wouldn't hurt to have a spare on hand, i have already went ahead and made an account and read the *how to order* through taobao and it seems fairly easy. Has there been any history of things missing in orders through them? i want to order a few things and dont mind the wait, but this is my first time buying through the site so im not sure how they work
Old 05-17-2015, 08:05 PM   #41
humanbeing's Avatar
SpudRider's guide: http://chinariders.net/showthread.php?t=14466
Vocab:
http://www.mychinamoto.com/forums/sh...ll=1#post21805
Old 05-17-2015, 10:18 PM   #42
I've ordered a few times, and I don't think there has ever been a missing item.
Old 05-26-2015, 05:36 PM   #43
Awesome! i will be making an order sometime this week. I had also received the Main Jets and Slow jets you sent me, thank you again! i will be giving them a try in the next day or so and see if my bike runs better. i will also be making a new thread this week regarding a CG250 that came in for a top end rebuild, i dont know what the guy done to it but it was seeping oil out the exhaust port and out of the intake . i plan to tear into it tomorrow im assuming it will be bent valves, he told me he was doing "wheelies" and started shooting oil and leaking everywhere, also said before it happened his engine was ticking really loud, from the sounds of it the thing will need new valves and seals also valve clearance, maybe even a new complete top end just for the sake of it. i have a few spare parts i bought in bulk last year so i wont have to wait for valves and gaskets ect. should be a pretty fun tear down!
Old 05-26-2015, 08:58 PM   #44
You're welcome.
I'm looking forward to that new thread! If a wheelie was pulled for a long enough distance (and maybe the oil level was a little low), do you think the oil pump would starve?
Brandon (my honourary Son) has a Gio with a CG230 in it, and I think it suffered a similar fate. He's going to install a spare CG I have for now, and we'll tear into the 230 soon. We'll be watching your thread for educational and entertainment purposes.
