#31 |
Does the large sprocket on the axle have provisions for it to slide on the axle. Maybe you can move it to help align the motor.
#32 |
It does but only half an inch
#33 |
Most centrifugal clutches can be mounted either way; you can have the sprocket facing out or in.
#34 |
This clutch doesnt havw that option its just put on and screw in
#35 |
What I mean is that your clutch can be mounted onto the shaft either way. Right now, you have the clutch sprocket facing out; remove the clutch and flip it around, and the sprocket will be facing in. Does that help you?
#36 |
I cant do that the bore is only 1" from one side and i cant flip it to face the opposite direction
#37 |
if you could flip it around, would that help you?
#38 |
![]() i cant flip the clutch it wont fit on the shaft |
#39 |
I understand. What I'm asking is, if you could flip it around, would that solve your problem?
#40 |
Flip the clutch or the big sproket?
#41 |
The whole device. When a centrifugal clutch is mounted on a minibike, it is common to install it so the sprocket is facing the engine, and Comet makes one that will install either way.
There's a pic on this minibike forum that shows what I mean. It is using a jackshaft, but ignore that part. Notice how the clutch is installed so the sprocket is facing the engine: http://www.oldminibikes.com/forum/ge...lutch-tav.html
#42 |
I knew what you meant this clutch is the cheap comet clutch it has like a cap so it wont slide on the shaft or if i try i cant put the cluth so that the sprocket faces in
#43 |
Right, but you could buy a clutch that can be installed either way. Before buying one, see if that would solve your problem.
#44 |
Ohh. well there expensive the 1" bore, but ill keep that in mind if this one messes up
#45 |
I changed the big sproket more to the left but it still needs a steel plate
