Thread Tools Display Modes
Old 02-04-2010, 08:20 AM   #16
katoranger's Avatar
Originally Posted by montanaoffroader
Last summer a friend of mine had similar problems with a 92 Exploder, turned out to be a bad intake gasket. Took us a little while to figure it out, it threw out a bunch of codes in KOER test.
With 300k on the clock, I think I would check the compression before I spent any real money on it, though.
Just my $.02
Good Luck, Mike
A think a replacement vehicle is on the short list. I haven't been back over to try anymore things.
Old 02-04-2010, 09:43 AM   #17
Reveeen   Reveeen is offline
Originally Posted by AZ200cc
Originally Posted by TurboT
..or you could do away with it and drive a DODGE. Fix all your problems.
..good luck with it.
Thats funny, I sell more parts for new dodges than any other car on the road. The vehicle I sell the least parts for are Subarus and Hondas....Fords are the hardest to figure out because they change a part every six months and chevys can't make a fuel pump or a cv shaft last to save a life. My best advice is to purchase an older vehicle with simple problems or buy A subaru or Honda. I might also go with only a newer chevy..They are fighting hard to get back in the quality fight.
Fixing Dodges kept me in grocery money for many years!
@300,000 I would do a complete "old-time" diagnostic: check compression and *timing chain* (if not a 4 cylinder) use an ohm meter on the wires, clean-up check coil packs/distributor (if a distributor check the advance mechanisms, both mechanical and vacuum, check vacuum advance for vacuum supply) look/check the EGR system, including function and gasket. The thing has to be reasonably healthy before you go sensor hunting.
Old 02-04-2010, 11:04 AM   #18
katoranger's Avatar
I am thinking that the compression is probably getting low. It is a 4.0 v6. I am not sure if has a distributor or not.
Compression test? Those plugs are not easy to find. Can't I just pushed it off a cliff.
Allen
Old 02-05-2010, 07:44 AM   #19
davidsonsgccc   davidsonsgccc is offline
if you should decide to push it off a cliff make sure there isnt a forum member riding at the bottom. 8O
my help may not be the best but it is free+-Seek ye first the kingdom of GOD
Old 02-05-2010, 08:22 AM   #20
katoranger's Avatar
I believe it is soon destined for the craigslist. About the only thing it has going is a straight body.
Old 02-06-2010, 05:01 PM   #21
katoranger's Avatar
Well I installed a used MAF sensor and the check engine light went out. Seems to be running pretty good too.
Also put in a used blower fan so she will have heat. Will see if we made and improvement. I was getting all set too run the diagnostics.
Allen
