Old 01-27-2023, 06:54 PM   #16
knwilson   knwilson is offline
Originally Posted by TominMO View Post
Is there any slack in your throttle cable? Is it sticking open?
Doesn't seem to be sticking. I can still rev it and it releases instantly. Throttle response is actually really nice - way better than before with all the hesitation and wandering idle. Just way too high.
Old 01-27-2023, 06:55 PM   #17
You’re sure the slide isn’t in 180* off?
Would it even go back together that way? Lol
Old 01-27-2023, 07:00 PM   #18
I thought they were "keyed" to only allow correct install? I thought I could only install it one way? I can unscrew that and take another look pretty easily though (I think there's room)...
Old 01-27-2023, 07:26 PM   #19
They are keyed, but in a way that if you put it in incorrectly it won’t close all the way. I’m not sure that it could even go together if it was backwards.
Old 05-10-2024, 10:59 AM   #20
vividpixel   vividpixel is offline
vividpixel's Avatar
I want to bump this thread because it was one of two I found while troubleshooting my problem recently. The throttle cable was just too short. Nibbi sells a longer 40.3“ cable and that worked great. Cable has room under the tank to curve gently away from the throttle without pinching.
Templar X 250: 14t / 42t, Nibbi PE30
