Go Back   ChinaRiders Forums > Media/Reviews/Classifieds/Sponsors > Web Deals - NEW!
Old 08-23-2021, 05:55 PM   #16
Marc Hufnagel   Marc Hufnagel is offline
So after speaking with 12oclock labs - I apparently have a 'dirty' signal on the speedo sensor on my Brozz 250. It was suggested I get some 0.1uf capacitors to 'clean it up'. I would have thought that for 80.00 they could have sent me a .25 component or three. After about 7.00 I have some coming tomorrow so I guess we shall see what they do. Hope it fixes it.
Old 08-28-2021, 07:31 PM   #17
JohnC   JohnC is offline
Originally Posted by Marc Hufnagel View Post
I have no idea then. Using that I get 9.09
With it still inline I did a factory reset and drove forward a bit and got wildly fluctuating numbers which I also got using 9.09 (both negative percent and positive just for fun)
I started having that issue with my Speedodrd. When starting the bike, the speed would go crazy, 3 digit numbers flashing as fast as it could go. Of course adding miles on the OD as well. It would stop if I moved the bike around, most of the time, else I would shut it down. I talked to the company support and he pretty much gave me the, it's a chinese bike electrical noise issue. He suggested a capacitor in the circuit might clean it up.
Anyway, I have it off now. I'm not sure what to do with it.
I was looking at the digital cluster that Stewbrash purchased because the wheel diameter can be programmed. Which I think is likely the problem all along. I think there might be a link here somewhere, but haven't found it yet.
John
Old 08-31-2021, 11:46 AM   #18
stewbrash's Avatar
John...it you're needing the link to the Speedometer...here you go:
https://www.aliexpress.com/item/1005...%2223416%22%7D
Old 08-31-2021, 11:48 AM   #19
stewbrash's Avatar
JohnC, here's the link to the adjustable speedo:https://www.aliexpress.com/item/1005...%2223416%22%7D
Old 08-31-2021, 02:17 PM   #20
stewbrash's Avatar
Here's a different style:https://www.aliexpress.com/item/1005...%2223416%22%7D
