Old 09-24-2019, 03:02 PM   #16
Did you pull the plug yet? It could tell a story rich vs lean
Sanddog is correct, you should buy a cheap lawnmower tach to tell you what your RPMs are ..get closer to this being an exact science than a guess
Old 09-24-2019, 05:43 PM   #17
OneLeggedRider's Avatar
Carb adjustment basics and standards.
A VERY long time ago carb manufacturers realized there needed to be a standard adjustment/setting for the fuel mixture screw so your average mechanic could accurately tune various carburetors without much difficulty. And here it is, regardless if it's on a car, bike, lawnmower, etc..
The starting position is 1.5 turns out from lightly seated (don't crank it down), and then you turn the screw in or out until you achieve your highest/best idle rpm, and then you turn the screw back just far enough to detect the slightest rpm drop. If this setting is below 1 turn out from lightly seated you need a smaller pilot jet, if it's above 2 turns out you need a bigger pilot jet.
From there it's on to the main jet. Start with a medium jet size for the particular carb you're tuning (we'll say a 110 for the stock or clone carb) and see how it runs. If it bogs at WOT but runs better with a little less throttle you're probably too big on the jet size. If it runs better at WOT with half choke or sounds revvy and poppy, or if you notice your exhaust pipe is getting really hot, you need a bigger jet.
Once you think you're close then it's on to WOT "plug chop" runs (hate that terminology). Which involves bringing the bike up to operating temperature, putting a brand new plug in it, and winding out every gear at full throttle and then hitting the kill switch before you let off the gas and let it coast to a stop. If the plug looks white or an ashy gray then you need to go up a size. If the plug looks black and sooty you need to go down a size. What you're looking for is the porcelain around the center electrode to be a brown color and the outer part a dark color.
Now it's on to the needle (needle jet jet needle is the proper term). You would have already set this at the center C-clip/or stock position for the above tuning adjustments. If you feel a slight bog as you're twisting the throttle/coming off idle then you need to raise the needle/lower the C-clip. I personally raise the needle as far as I can go without getting dark smoke and losing acceleration characteristics, you're looking for a smooth transition.
And after all of that... you go back to the A/F mixture screw and fine tune it as previously described, and then do some overall plug readings to be sure all is well. You're bike should start well with minimal choking, not bog slightly at WOT, and shouldn't snap crackle and pop when you let off the throttle.
Old 09-24-2019, 07:14 PM   #18
thepostman4   thepostman4 is offline
If its bogging no matter what main jet you use, it's possible that your float valve needs to be adjusted. If the fuel level in the bowl is too high it will cause the engine to run rich.
Also what altitude are you at?
Old 09-24-2019, 07:51 PM   #19
AresROC   AresROC is offline
AresROC's Avatar
Originally Posted by OneLeggedRider View Post
Super nice info thanks! Exactly what I need to tune my carb.
I came across this info for 2-strokes maybe for the most part it will work for 4-strokes?
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D
JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair .
Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2
BSR Chronicles - "Project leads to more projects!"
Yamaha WR250R
Suzuki GSX-R 600
Old 09-24-2019, 07:52 PM   #20
CaesarVis   CaesarVis is offline
The plug is VERY dark right now. @thepostman4, I'm either right at or slightly below sea-level. Would the needle air/fuel screw on the bottom being out of adjustment cause the bogging and smoking I am seeing now? It really is a pain in the ass because I have to take the whole damn carb off the bike to make an adjustment then repeat the whole process...unless I'm missing something.
Old 09-24-2019, 08:17 PM   #21
That's good information for a 2-stroke with an air screw, but doesn't really apply to our 4-strokes with a fuel screw.
Float height is important too. The standard for it is to hold the carb upside down with the bowl off. The top of the float should be horizontal with the float bowl mating surface.
Old 09-24-2019, 08:24 PM   #22
OK, more information. I found a picture of the carb I took the other day and I THINK I got the fuel/air screw back to where it was before but it's still bogging out. In neutral, when I rev it, it starts to crap out between 3,000-4,000 rpm and WILL NOT go above 4,000 rpm. Any ideas what would cause that?
Old 09-24-2019, 08:47 PM   #23
Did you adjust the valves? That would one of the 1st things to do before trying to tune.
2020 Kawasaki Vulcan S
2004 Honda ST 1300
Old 09-24-2019, 08:58 PM   #24
Alright guys, I figured out the issue and I feel dumb now! I NEVER use the choke so didn't really know what direction was what. I thought up was off but apparently up is ON. I have had the damn choke on this WHOLE freaking time. Thank you so much to everyone that assisted me and I'm sorry to have wasted your time. At least some other good discussions took place!!! Thanks again guys! This community really is amazing!
Old 09-24-2019, 08:59 PM   #25
I have adjusted the valves a couple of times. Most recently a couple of days ago to 0.003/0.004 on intake and exhaust.
Old 09-24-2019, 09:01 PM   #26
No problem. Just glad we could help out. You're not the first to do that. Lol
2004 Honda ST 1300
Old 09-24-2019, 09:24 PM   #27
NzBrakelathes's Avatar
Originally Posted by CaesarVis View Post
@JerryHawk250 - I'm going to try that this evening. Is there an easy way to adjust this thing WITHOUT having to take the whole damn carb off every time??? Also, we have the same bike and live pretty close to each other; do you think I should go ahead and get a Mikuni? Something's just not right with this one. I mean you (and many others) recommended a 110 jet and that just made my carb absolutely spazz out and not even start/idle! Also, do you know anywhere locally I can get this "d-shaped screwdriver" or will my only options be online?
@sandog - I PMed you but if you don't see that, the "screw" in my picture is NOT the idle RPM screw, it's the air/fuel mixture. If your bike is idling too high, there's a flat-head "screw" type of thing with a spring on it on the right side of the carb. Clockwise increases idle RPM and counter-clockwise decreases idle RPM. Just make small adjustments and listen to it. Having an RPM gauge is helpful too. I bought this one and it works pretty well: https://www.amazon.com/gp/product/B01CR2IC2Q
@NzBrakelathes - I see that's your eBay store and no offense, but I could buy a whole new Mikuni style carb for about the same price as that kit. I also don't need the sprocket as the Storm comes with the proper one.
@herbie - I really don't think it's a fuel issue. I only ever put 100% gasoline in it, the bike is only 6 months old and I rode it last about a month ago (it's been stupid hot lately).
Thanks for the input everyone! I will definitely keep you updated as to what is going on.
trhere is a special tool you can use to adj the screw, I dont have the link but maybe search past threads
Old 09-24-2019, 10:03 PM   #28
Well atleast my fingers got a good workout..
Old 09-25-2019, 05:46 AM   #29
https://rover.ebay.com/rover/0/0/0?m...2F282737934297
Old 09-25-2019, 07:39 AM   #30
Nice tool but won't work with his carb. It has the D shaped end on the idle mixture screw.
2004 Honda ST 1300
bogging, carb, dies, tuning
