Old 05-12-2016, 10:49 AM   #16
Removal is ok for testing, but I don't recommend poking a hole in it. That's not easily reversible.
Old 05-12-2016, 10:53 AM   #17
newrider93   newrider93 is offline
newrider93's Avatar
Probably the best upgrade is to go on a diet and for some of us lose about 20 lbs, talk about performance improvements!
Haha. Lol. True, true, true.
My YouTube channel where you can check out my hawk and other cool stuff:
https://www.youtube.com/c/Andrew93
newrider93 AKA Andrew93
Old 05-12-2016, 04:15 PM   #18
zingshoen   zingshoen is offline
zingshoen's Avatar
what about the weight of the stock muffler? an unrestricted header and lightweight performance muffler will make a noticeable difference with the right carbie setup.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
Old 05-12-2016, 04:26 PM   #19
One of the most important things you can do is keep your options open until it's broke in. These CG motors change personality continuously (at least all of mine have) until they're loosened up.
Old 05-12-2016, 04:37 PM   #20
Azhule   Azhule is offline
I'm one of the few who can't afford to lose any more weight, my motorcycles have to do that for me
So once my friend gets his TIG welder I will drop a good 15 - 16lbs off our Bashan WILL exhaust system , that combined with weight I dropped off when I ditched the bulky air box/emissions nonsense that 'didn't do squat' for a UNI Pod Filter... the bike is almost to that "20 lb diet requirement" , and it should have a few extra ponies too the way the exhaust was restricted on our bike
Old 05-13-2016, 09:27 AM   #21
Swollbraham   Swollbraham is offline
Swollbraham's Avatar
Removed baffle last night did maybe 20 miles to test. I couldn't really tell differences it felt more stable at 60ish but I also removed my rubbers from the foot pegs. Also, it felt like it let open a little more while at full throttle. But nothing substantial to report on preformance. Sound wise, a 100 times better it sounds really good with the baffle removed. I would recommend this to anyone, just to have a little louder exhaust to make people more aware around you. i think this is all I'm going to do with the exhaust for awhile I'll update when I decide to swap it or mod it anymore.
Old 05-13-2016, 03:07 PM   #22
pcspecialist   pcspecialist is offline
Originally Posted by Swollbraham View Post
Here is a list of all mods done on my hawk 250,
7th swapped my rear sliders to washers and bolts, chain seems to rub on the factory ones. (This could be an assembly problem)
8th swap chain guide.
Please post pictures and more info.
Thanks
Old 05-13-2016, 03:31 PM   #23
Thanks
Will do that. I'm still
Making a few mods. Will post pics here in the next few days. What kind of info do you want?
2008 CRF 450
2015 hawk 250
-Ancap Revolution-
"There can be no such thing as 'fairness in taxation.' Taxation is nothing but organized theft, and the concept of a 'fair tax' is therefore every bit as absurd as that of 'fair theft.'"
-Murray Rothbard
Old 05-13-2016, 03:44 PM   #24
just more info on 7 & 8
Old 05-13-2016, 03:54 PM   #25
i'll have to take some pics.
but basicly, the bracket and nuts (Rear slider) that are used to to tighten the chain they are shit. so i swapped them for better washers and nuts.
the chain guide, is the rubber piece on the frame that helps guide the chain into the countershaft sprocket. on my bike if you lined up your sprockets perfectly this chain guide actually will not line up with countershaft. so i got rid out it, this won't necessarily throw the chain, but it's not helping.
2008 CRF 450
2015 hawk 250
-Ancap Revolution-
-Murray Rothbard
Old 05-13-2016, 04:37 PM   #26
so you didn't swap the chain guide, you simply removed it?
I was thinking about filing down the ridge on it so it no longer guided the chain but did protect the swingarm.
Old 05-13-2016, 04:54 PM   #27
yes i finally removed it. i did try to swap it with a old honda chain slider but couldn't get that to quite line up either. also just filing it down is probably a better idea haha
2008 CRF 450
2015 hawk 250
-Ancap Revolution-
-Murray Rothbard
Old 05-13-2016, 05:31 PM   #28
You probably won't notice much as long as the cat is upstream. That's your main exhaust flow obstacle.
Old 05-14-2016, 01:34 AM   #29
Entropy   Entropy is offline
I just put on a Pro Circuit T4 on my Hawk tonight. It's loud...
Old 05-14-2016, 09:48 AM   #30
BARLOW   BARLOW is offline
BARLOW's Avatar
Thanks for report. You may find a replacement header pipe without the catalytic converter 4 cheap. I think the one for the bashan storm was $10-15 or so
do you know where to get one for that price ... only one i found was over $60 ... i would get one for sure at that price
baffle, enduro, hawk, mods
