Old 03-09-2014, 12:46 PM   #16
Neutral was a bear in my son's bike as well. Good quality synthetic oil helped a bit.
Old 03-10-2014, 12:54 AM   #17
pete   pete is offline
pete's Avatar
Terrific pics!
Son of Weldangrind had the same bike, and I actually changed the front sprocket to a 12 tooth. The secret was to swap to stainless socket head cap screws, which gave the chain the clearance it needed.
I have ordered new sprockets.... but I had a thought... replace the retaining
plate/bolts with a circlip...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 03-10-2014, 10:40 AM   #18
tpar1220   tpar1220 is offline
when you go from 13/41 to 15/48 you will certainly need a longer chain. thats a big jump!
Old 03-10-2014, 10:54 AM   #19
Not sure I'd trust a circlip near my kid's leg.
Old 04-04-2014, 09:00 PM   #20
pete's Avatar
Thumbs Down
The dam little chinese shitter tossed the chain... broke the side case & broke the pick up
off the stator plate..
New stator plate/coils/pick up.. only worth $26nz.. At least the parts are
worth almost nothing for these things..
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 04-05-2014, 12:27 PM   #21
Exactly the reason that I toss China chains in the bin. I usually use an RK or a DID.
Is your Son ok?
Old 04-05-2014, 05:40 PM   #22
pete's Avatar
Is your Son ok?
Yes.... diddn't do any damage to him..
May have been my falt......
The chain tention works oppisite to a real bike... As the suspesion compresses
the chain gets loser... Not tighter as on ever other bike I have had...
May have had to much free play in it to start with..
Have also ordered a chain guide for it..
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 05-10-2014, 12:22 AM   #23
pete's Avatar
This dam little @#$&*% still tosses it chain...
looks like I will have to move the swing arm pivot up
about 40mm to cure the issue... Which is in fact quite easy
to do with the way the arm is mounted...
But first I'm going to try a trick we used on the speedway TQ midget
years ago.... A nylon disc bolted on each side of the sprocket that sits
25mm higher... to guide the chain onto the sprocket... In 4 years of
raceing I never tossed a chain after putting them on...
But other than the chain... it's not a bad little bike for the $...
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 05-10-2014, 03:48 AM   #24
I wonder what the difference is with your model. My son's 125 never tossed the chain.
Old 05-10-2014, 05:08 AM   #25
pete's Avatar
Prise ?
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 05-10-2014, 11:17 AM   #26
Ours was definitely bottom shelf. We paid too much at $800.00 Canadian out of the box. Last year, I saw the big wheel version for $400.00.
The basic platform was ok, but the welds, bearings, seals, chain and sprockets were junk. After I replaced those and took the time to set it up, it was a reliable little machine.
Old 05-10-2014, 08:15 PM   #27
pete's Avatar
This one cost $895NZ... The cheapest yer can get here for the BW version..
like your's its ok apart from this dam chain issue... once thats sorted it
should quite relieable..
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 05-19-2014, 01:42 AM   #28
pete's Avatar
bolted a nylon guide disc each side of the sprocket.... 2 days riding with out tossing a chain...
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 05-20-2014, 11:08 AM   #29
I got thinking about Caleb's bike over the weekend, and I think that we were also having some chain issues in the beginning. The only repair I completed that would have corrected it was to replace the swingarm bushings with Honda parts.
I didn't start a thread on it, but I remember taking the old bushings to Honda, and the guy matched them for me. Good job that he keeps all of the bushings in one box. I paid less than $10 per bushing, and it made all the difference in the swingarm.
Old 05-21-2014, 01:17 AM   #30
pete's Avatar
It has rubber bushes in the swing arm pivot... i will look at the honda brearings...
I am going to strip it down soon & move the swing arm pivot up 30mm which
is easy to do... make a new spacer tube , drill 2 holes & put the tube though
and weld it there.. I have looked at pics of a few of the higher prised pitbikes
they mount the arm higher up.. that will make the chain tighten instead of lossen
as the arm swings up..
I might also cut the frame just back from the steering head & add 50mm , 2" into
it..As I see there is a 2" longer version frame... longer frame would be better as caleb grows..
It also need a new shock... The spring seems to have compressed " to short for the shock now"
An't chinese bikes just so much fun....
PS.... also needs a steering stop that dosn't bend every time it's droped..
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
