Old 04-10-2022, 03:49 PM   #1
Mudflap   Mudflap is offline
Vitacci Clash 200 EFI Scooter
Pictures here:
https://www.vitacci.com/scooters/clash-200-efi
Well it's not actually 200cc, it has a Lifan 168cc, fuel injected version of a GY6 engine. The scooter itself is a clone of the Honda Click 150 which I don't believe was imported to the US.
I have one of these on order from Amazon and will post a review in a couple weeks.
Here are the published specs:
Model CLASH 200
Displacement 168cc
Ignition EFI
Engine Type LF161QMK
Maxi Speed 68 MPH
Fuel Tank 4.8L
Tire Size 80/90-14;90/90-14
Brake F: Disc / R :Drum
L*W*H(Inches) 81.4*28.7*44.4
Wheel Base(Inches) 52.3
Bore 61mm
Stroke 57.6mm
Battery Type 12V7A
Lights LED
Speedometer Digital
Maxi Power 6.8 (kw/8000min)*
Maxi Torque 9.6 (N.m/5500min)
Idle 1600±100
Compress Ratio 9.2:1
Weight (LBS) 232
Running Weight(LBS) 331
*Note the 6.8 kw max power is probably wrong because that is the published power of the 125cc carb version of that engine.
Old 04-10-2022, 05:04 PM   #2
Boatguy   Boatguy is offline
Boatguy's Avatar
What is the running weight?
I probably should know that, but I have no idea why it’s 100 pounds more than the weight.
2020 Lifan x-pect
Old 04-10-2022, 08:53 PM   #3
Maybe running weight means shipping weight?
Old 04-10-2022, 06:30 PM   #4
wheelbender6's Avatar
They call it a “200” if it is any bigger than a 150cc these days.
“It is the Way”
Genuine scooter company is the only exception that I know of.
For some strange reason, they refer to their 168cc Buddy and Hooligan
As “170s”.
Old 04-11-2022, 06:54 AM   #5
Clash200EFI   Clash200EFI is offline
I also ordered one. Hoping it does not have stalling issues like the Spark 150. I've read that there's an automatic choke that causes flooding even when at temp. Also, one Spark 150 rider had to turn out screw 3.5 turns for sea level because it was running so rich. Please post any steps here from unboxing to tuned for road and issues, solutions. I'll do same
Old 04-11-2022, 09:18 AM   #6
I was originally looking at the Spark 150 and read about the carb issues. That would be easy enough for me to remedy but then I discovered the EFI Clash which is basically the same but with EFI and a bit more power and a Lifan engine. I wanted a flat floor, large diameter wheels, a 150cc GY6 engine for easy parts availability. Good to have someone to share tips with.
BTW they shipped UPS and the stated shipping weight is 311 lbs. 331 lbs is a common load capacity for smallish bikes so that's probably what is meant by "running weight."
Old 04-11-2022, 04:52 PM   #7
olds_cool63   olds_cool63 is offline
olds_cool63's Avatar
Who actually manufacturers their scooters and motorcycles?
Nuff said.
olds_cool63
Johnny Pag Pagsta (replaced 50cc engine with 110cc, modded-out)
2007 Tank Vision Topline Khaos (cosmetic mods, cherry-bombs)
2005 Kymco Vitality 50 2T (70cc big bore kit, other race mods...tops out at 67mph)
2008 Hyosung GT250 (cosmetic mods)
2001 Suzuki Bandit GFS1200S (cosmetic and slight mods...150mph+)
Old 04-11-2022, 09:45 PM   #8
Sometimes the manufacturer will be listed on the VIN plate but it may just say Vitacci. Judging by their rather large line of vehicles it's likely Vitacci buys complete vehicles from many manufacturers and puts their name on them. In the case of the Clash the engine number indicates it is a Lifan but the rest of the scooter may well be made by another manufacturer.
Old 04-12-2022, 04:08 PM   #9
I've been looking at Vitacci's recently. That model was on my short listas well as the GTS 250, which is no way a new model, but still cool: https://www.vitacci.com/scooters/gts-250cc/
Nuff said.
olds_cool63
Old 04-12-2022, 05:03 PM   #10
I like the design of that one with storage like a Helix but Vitacci needs to correct their specs. 7.8 hp and top speed of 56 mph?
Old 04-12-2022, 08:00 PM   #11
Here is a used China Falcon 200 on my local craigslist that I'm sort of mulling over.
Hurry up and ride your Vitacci so you can advise me, Mudflap.
It looks quite a bit different, but is probably mechanically very similar.
Tempting at $1,300 with 5 miles on the clock.
https://houston.craigslist.org/mcy/d...469258458.html
Old 04-12-2022, 09:04 PM   #12
Engine is probably identical to the Clash except for fuel injection and maybe a different manufacturer. Many of the Chinese scooter importers are based in Texas so you may be able to choose any one you want and pick it up instead of paying shipping.
Old 04-17-2022, 10:39 AM   #13
Smart Deals Now is the seller on Amazon and so far I give them a thumbs up. I've had a couple questions about shipping with UPS freight and a real person has answered the phone and responded quickly to messages. The scooter was shipped out of the LA California area.
BTW UPS shipping is pretty terrible about "incidents" causing delays and updating tracking info.
Old 04-22-2022, 08:47 AM   #14
Barnone   Barnone is offline
Barnone's Avatar
Waiting on the new owners here and on ADVrider to get some miles on their Clash 200.
Old 04-22-2022, 05:07 PM   #15
A caution for anyone buying through Amazon: The advertised shipping company is UPS but it's actually TFF that used to be UPS Freight. They appear to be totally incompetent. 1st delivery date from their website was 4/13. No calls no show. That night it changed to 4/14. No call no show. Then 4/15 no call no show. Then 4/18 no call no show. Then I managed to talk to the local guy and made an appointment for 10 to 12 on 4/20. No call no show. Unable to get in touch with them since. May have to take a refund from Amazon.
