Old 04-09-2024, 09:08 AM   #1
HotTommy   HotTommy is offline
Where to put oil return port on Zongshen 200
Disregard.
Old 04-09-2024, 09:16 AM   #2
Aussie_in_MO   Aussie_in_MO is online now
That nut covers the screen for the oil "filter"
I'd almost be tempted to have a new oil fill cap machined up with a port so you can run the gravity drain line from your turbo in there.
2023 Templar X
2009 Triumph Bonneville
1976 Yamaha DT175
1974 Honda MT125
Old 04-09-2024, 09:21 AM   #3
Thanks. I discovered shortly after my post that my engine has two drain plugs - a small one on the bottom and the big one on the side. I'll adapt the big one for my purpose.
Old 04-09-2024, 05:03 PM   #4
The one on the side isn't considered a drain as it doesn't completely drain the oil out of the engine. It's called the filter cover. The actual drain is under the engine. In the above video, they should have drained the oil out of the bottom first. This would have taken the swarf and sludge out with the fast flowing oil. Then the side cover should've been removed to access the filter screen for cleaning.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
