It’s coming up too short on the inner cable the steel part is just barely too short even when the cable adjustments are shortened all the way. I have tried really everything but even if I try to take unbolt the shift arm or the attachment point for the cable and then reinstall it after the cable is installed it will have 0 room for free play or more than likely I wouldn’t even be able to reattach the shift arm or attachment point for the cable because there will be no room
